- Yesterday
- general chat
- general
(and 1 more)
Tagged with:
- Earlier
Really pops!
- honda civic mb
- chat
(and 2 more)
Tagged with:
- 6 comments
- honda civic ma
- honda civic 5 door hatch
- (and 2 more)
Ideal glad you got it sorted!
Thank for your help, i took the plung and just ordered it and i can confirm the Firstline FEM3499 fits perfectly so now its straightened up the engine and my back box dont knock against the rear strut anymore! 😁
Hello mate, not sure if you've got this sorted - you can use this site and put in your vin number. Then find the right drawing and it should tell you the part number https://www.parts-honda.uk/honda-cars/search_vehicle/chassis
Hi guys, im looking for a new replacement main LH engine mounting as its failing for my 2000 MB3 D15Z8, its an alloy type just wondering if anyone would know if a FirstLine FEM3499 will fit as looks identical to mine, I'm struggling to find one! I have attached pics but not too good! The last one is a stock FirstLine pic. Many thanks. Nick.
Yes it is a before and after. It has great shine when throwing flash light on it ☺️
Is that wrapped in that last video? The shine looks awesome and the amount of metallic in it is amazing!
That's a whole lot of work you've been doing mate, hats off to you! Nice to see these Civics being pampered and cared for.
- 8 replies
- honda civic mb
- honda civic mb4
(and 2 more)
Tagged with:
Sad to see you selling mate, really stunning deck that. If she does sell, be sure to point the owner here to the forum and our Facebook group. Would be nice to follow her progress.
Sorry for the delay, thanks Sir Paperbag/ Patrick ! I already have bright halogen H4s fitted, Philips, extreme/ race vision or whatever, as you say, theyre ok but still not great. the fog light idea is good, thanks. maybe with LED bulbs in there ? I have found some LEDs that look good, there are plenty available for not too silly money, will maybe try these but looks like might need to doctor the rubber boot, to clear the heatsink/ fan portion on these bulbs. I have cleaned the h/light lens as best I can, but have got a polishing kit to take out the remaining haziness, used just the polish so far but i think need to 'man up' and try the wet and dry. I see AKR have new units available from Depo at reasonable price, so that's an option. the other thing of course with halogens is to ensure the voltage drop is not excessive, previous car I fitted a relay kit, not an issue with LEDs as they operate from 8V. and current is lower. Re the switch it's ok at the moment so probably just needs a good clean with contact cleaner. below was the page I found, M series switch might be similar. thanks again. https://www.hondacivicforum.com/forum/routine-maintenance-diys-73/diy-combination-switch-fix-headlight-switch-74275/
Follow this two flowcharts. First check if you have any DTC store for the ABS. If the ABS light doesn't start blinking after one blink, you don't have any error stored. If you have an error, check that first. If the light is constantly on and doesn't enter in the DTC mode, you have a faulty ABS Module. If you don't know how to read ABS faults, just check the manual in the ABS section. If you need more help just PM me and i will help you in Portuguese.
Hi fellas's Its been a while. Sadly I've come to a positio where I have to let her go. It's been one hell of a journey but this car has been sitting under a tarp for long enough now. I think I've done a fair amount of mods and I've learned SO MUCH over the past 5 years of owning this car. Sadly I've grown up a little, got a stock '99 accord that I use for work... Hinata ended up outside for a while, now she sits in our new workshop under a cover. Been sitting for a year almost and barely driven. It hurts to look at her so i've been trying to sell it for sometime now. This sunday someones coming over to maybe take her and drive her again. It's a shame but i've been neglecting this car / focusing on other things for quite sometime and I just can look at her anymore. It's been wild, thanks :)
Can you send me some photos of this part of the ebd. Excuse my ignorance but I didn't find anything about this in the manual on this site
Can you tell me which page of the manual this is on? I didn't find anything talking about EBD
Every 99+ Civic have EBD. Check the 99 service manual available on this site. In my case, the problem was the ABS Module. I change that and the lights were immediately off.
